Análise estatística implicativa e análise de variância: estudo estatístico comparativo sobre o desempenho escolar em sala de aula multicultural - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2021
Statistical Implicative Analysis and analysis of variance: comparative statistical study on school performance in a multicultural classroom
Analyse statistique implicative et analyse de variance : étude statistique comparative sur la performance scolaire dans une classe multiculturelle
This work aims to investigate the influences of students’ culture on school performance under a mixed quantitative analytical methodology, consisting of analysis of variance (ANOVA) and Statistical Implicative Analysis (SIA). The study was carried out through the statistical analysis of data from the school record of the grades of urban, rural, indigenous and quilombola students from High School Integrated to the Agricultural Technician from 2011 to 2018 at the Federal Institute of Sertão Pernambucano in the city of Salgueiro-PE, Brazil. The results revealed that there is an influence of culture on the students’ academic performance, where the quilombolas make up the profile linked with the concept D income and consequently with school dropout. As for ANOVA and SIA, they are instruments that can complement each other, enriching data analysis, precisely because they are different. We consider that the use of SIA in research in the social area, specifically in education, can favor studies by enabling the understanding of the research object as a behavioral phenomenon, not static, which is subject to changes according to the influences of the various variables that make up the complex reality.
Ce travail vise à étudier les influences de la culture des élèves sur les performances scolaires dans le cadre d’une méthodologie analytique quantitative mixte, composée d’une analyse de variance (ANOVA) et d’une analyse statistique implicative (ASI). L’étude a été réalisée à travers l’analyse statistique des données du dossier scolaire des notes des élèves urbains, ruraux, indigènes et quilombola du Lycée Intégré au Technicien Agricole de 2011 à 2018 à l’Institut Fédéral du Sertão Pernambucano dans la ville de Salgueiro-PE, Brésil. Les résultats ont révélé qu’il existe une influence de la culture sur le rendement scolaire des élèves, où les quilombolas constituent le profil lié au concept D de revenu et, par conséquent, au décrochage scolaire. Quant à l’ANOVA et à l’ASI, ce sont des instruments qui peuvent se compléter, enrichir l’analyse des données, précisément parce qu’ils sont différents. Nous considérons que l’utilisation de l’ASI dans la recherche dans le domaine social, notamment dans l’éducation, peut favoriser les études en permettant la compréhension de l’objet de recherche comme un phénomène comportemental, non statique, qui est sujet à des changements selon les influences des différentes variables qui composent la réalité complexe.
Este trabalho objetiva investigar as influências da cultura dos estudantes no desempenho escolar sob uma metodologia analítica quantitativa mista, composta pela análise de variância (ANOVA) e a análise estatística implicativa (ASI). O estudo se deu pela análise estatística de dados do registro escolar das notas de estudantes urbanos, sertanejos, indígenas e quilombolas do Ensino Médio Integrado ao Técnico em Agropecuária, desde o ano de 2011 até 2018 no Instituto Federal do Sertão Pernambucano na cidade de Salgueiro-PE, Brasil. Os resultados revelaram que há influência da cultura no rendimento escolar dos estudantes, onde os quilombolas compõem o perfil vinculado com os rendimentos de conceito D e consequentemente com a evasão escolar. Quanto a ANOVA e a ASI são instrumentos que podem se complementar enriquecendo a análise dos dados, justamente por serem diferentes. Consideramos que a utilização da ASI em pesquisas na área social, especificamente educacional, pode favorecer os estudos por possibilitar a compreensão do objeto de pesquisa como um fenômeno comportamental, não estático, que está sujeito às mudanças conforme as influências das diversas variáveis que compõem a realidade complexa.
Fichier non déposé
hal-03421603 , version 1 (09-11-2021)
  • HAL Id : hal-03421603 , version 1
Rafael Santos de Aquino, Ana Maria dos Anjos Carneiro-Leão, Vladimir Lira Veras Xavier de Andrade, Nadja Acioly-Regnier, Jean-Claude Régnier. Análise estatística implicativa e análise de variância: estudo estatístico comparativo sobre o desempenho escolar em sala de aula multicultural. Jean-Claude Régnier; Régis Gras; Antoine Bodin; Raphael Couturier. Analyse statistique implicative Analyses quali-quantitatives des liens orientés entre variables et/ou groupes de variables, Université de Bourgogne- Franche Comté, pp.169-189, 2021, Imprimé : 978-2-9562045-5-8; Numérique: 978-2-9562045-4-1. ⟨hal-03421603⟩
88 Consultations
0 Téléchargements
