Faster floating-point square root for integer processors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Claude-Pierre Jeannerod
  • Fonction : Auteur
  • PersonId : 855152
Hervé Knochel
  • Fonction : Auteur
  • PersonId : 855153
Christophe Monat
  • Fonction : Auteur
  • PersonId : 855154
Guillaume Revy
This paper presents some work in progress on fast and accurate floating-point arithmetic software for ST200-based embedded systems. We show how to use some key architectural features to design codes that achieve correct rounding-to-nearest without sacrificing for efficiency. This is illustrated with the square root function, whose implementation given here is faster by over 35% than the previously best one for such systems.
sqrt-SIES2007.pdf (164.13 Ko) Télécharger le fichier
hal-03424131 , version 1 (10-11-2021)
Claude-Pierre Jeannerod, Hervé Knochel, Christophe Monat, Guillaume Revy. Faster floating-point square root for integer processors. 2007 International Symposium on Industrial Embedded Systems, Jul 2007, Lisbon, Portugal. pp.324-327, ⟨10.1109/SIES.2007.4297353⟩. ⟨hal-03424131⟩
30 Consultations
164 Téléchargements
