Differentially Private Coordinate Descent for Composite Empirical Risk Minimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Machine learning models can leak information about the data used to train them. To mitigate this issue, Differentially Private (DP) variants of optimization algorithms like Stochastic Gradient Descent (DP-SGD) have been designed to trade-off utility for privacy in Empirical Risk Minimization (ERM) problems. In this paper, we propose Differentially Private proximal Coordinate Descent (DP-CD), a new method to solve composite DP-ERM problems. We derive utility guarantees through a novel theoretical analysis of inexact coordinate descent. Our results show that, thanks to larger step sizes, DP-CD can exploit imbalance in gradient coordinates to outperform DP-SGD. We also prove new lower bounds for composite DP-ERM under coordinate-wise regularity assumptions, that are nearly matched by DP-CD. For practical implementations, we propose to clip gradients using coordinate-wise thresholds that emerge from our theory, avoiding costly hyperparameter tuning. Experiments on real and synthetic data support our results, and show that DP-CD compares favorably with DP-SGD.
preprint.pdf (564.62 Ko) Télécharger le fichier
hal-03424974 , version 1 (10-11-2021)
hal-03424974 , version 2 (02-02-2022)
hal-03424974 , version 3 (21-10-2022)
  • HAL Id : hal-03424974 , version 2
Paul Mangold, Aurélien Bellet, Joseph Salmon, Marc Tommasi. Differentially Private Coordinate Descent for Composite Empirical Risk Minimization. 2022. ⟨hal-03424974v2⟩
115 Consultations
103 Téléchargements
