Comments on the cosmic convergence of nonexpansive maps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Fixed Point Theory and Applications Année : 2021
This note discusses some aspects of the asymptotic behaviour of nonexpansive maps. Using metric functionals, we make a connection to the invariant subspace problem and prove a new result for nonexpansive maps of $\ell^{1}$. We also point out some inaccurate assertions appearing in the literature on this topic.
CosmicConvergence.pdf (283.51 Ko) Télécharger le fichier
hal-03426011 , version 1 (11-11-2021)
Armando W. Gutiérrez, Anders Karlsson. Comments on the cosmic convergence of nonexpansive maps. Journal of Fixed Point Theory and Applications, 2021, 23 (4), ⟨10.1007/s11784-021-00896-8⟩. ⟨hal-03426011⟩
47 Consultations
55 Téléchargements
