Object Detection with Component-Graphs in Multi-band Images: Application to Source Detection in Astronomical Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Access Année : 2021
In the context of mathematical morphology, component-graphs are complex but powerful structures for multi-band image modeling, processing, and analysis. In this work, we propose a novel multiband object detection method relying on the component-graphs and statistical hypothesis tests. Our analysis shows that component-graphs are better at capturing image structures compared to the classical componenttrees, with significantly higher detection capacity. Besides, we introduce two filtering algorithms to identify duplicated and partial nodes in the component-graphs. The proposed method, applied to the detection of sources on astronomical images, demonstrates a significant improvement in detecting faint objects on both multi-band simulated and real astronomical images compared to the state of the art.
IEEE_ACCESS_Journal_2021__Final.pdf (9.5 Mo) Télécharger le fichier
hal-03429058 , version 1 (15-11-2021)
hal-03429058 , version 2 (19-11-2021)
Paternité
Thanh Xuan Nguyen, Giovanni Chierchia, O Razim, R Peletier, Laurent Najman, et al.. Object Detection with Component-Graphs in Multi-band Images: Application to Source Detection in Astronomical Images. IEEE Access, 2021, 9, pp.156482-156491. ⟨10.1109/ACCESS.2021.3128519⟩. ⟨hal-03429058v2⟩
78 Consultations
51 Téléchargements
