New interface
Conference papers
Reduced Order Fast Converging Observer for Systems with Discrete Measurements
Abstract : We study continuous-time nonlinear systems, first in the case where there are continuous output measurements and next in the case where there are only discrete output measurements. When continuous measurements are available, we provide observers that converge in finite time. When only discrete measurements are available, we provide observers that do not converge in finite time, but which do converge asymptotically with a rate of convergence that is proportional to the negative of the logarithm of the size of the sampling interval. We illustrate our results in a pendulum example.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-03431239
Contributor : Frederic Mazenc Connect in order to contact the contributor
Submitted on : Tuesday, November 16, 2021 - 3:36:54 PM
Last modification on : Friday, November 18, 2022 - 9:28:26 AM
Long-term archiving on: : Thursday, February 17, 2022 - 8:02:21 PM
File
2Dec2019ZPJMTNS20.pdf
Identifiers
  • HAL Id : hal-03431239, version 1
Citation
Frederic Mazenc, Michael Maliso, Zhong-Ping Jiang. Reduced Order Fast Converging Observer for Systems with Discrete Measurements. MTNS 2021 - International Symposium on Mathematical Theory of Networks and Systems, Aug 2021, Cambridge, United Kingdom. ⟨hal-03431239⟩
Share
Metrics
Record views
12
Files downloads
38
