New interface
Conference papers
Stability Analysis using New Variant of Halanay's Inequality
Abstract : We present a generalized form of Halanay's inequality, having a time varying gain multiplying the delayed term and a constant decay rate. Unlike the usual Halanay's conditions where the decay rate is required to exceed an upper bound on the gain multiplying the delayed term, we provide less restrictive conditions that allow times when the decay rate can be strictly less than the gain. We include an application to continuous time systems with switched delay values. This illustrates the utility of our generalized Halanay's inequality conditions for proving asymptotic stability in significant cases that violate the contraction condition that was needed to prove asymptotic stability in previous trajectory based results, and which are also not amenable to previous Lyapunov function constructions.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-03431280
Contributor : Frederic Mazenc Connect in order to contact the contributor
Submitted on : Tuesday, November 16, 2021 - 3:47:53 PM
Last modification on : Friday, December 2, 2022 - 11:52:04 AM
Long-term archiving on: : Thursday, February 17, 2022 - 8:05:02 PM
File
2Feb2020FMMTNS20.pdf
Identifiers
  • HAL Id : hal-03431280, version 1
Citation
Frederic Mazenc, Michael Malisoff, Miroslav Krstic. Stability Analysis using New Variant of Halanay's Inequality. MTNS 2021 - International Symposium on Mathematical Theory of Networks and Systems, Aug 2021, Cambridge, United Kingdom. ⟨hal-03431280⟩
Share
Metrics
Record views
7
Files downloads
69
