An End-to-End Approach for Full Bridging Resolution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this article, we describe our submission to the CODI-CRAC 2021 Shared Task on Anaphora Resolution in Dialogues – Track BR (Gold). We demonstrate the performance of an end-to-end transformer-based higher-order coreference model finetuned for the task of full bridging. We find that while our approach is not effective at modeling the complexities of the task, it performs well on bridging resolution, suggesting a need for investigations into a robust anaphor identification model for future improvements.
2021.codi-sharedtask.5.pdf (279.41 Ko) Télécharger le fichier
hal-03431313 , version 1 (16-11-2021)
Paternité
  • HAL Id : hal-03431313 , version 1
Joseph Renner, Priyansh Trivedi, Gaurav Maheshwari, Rémi Gilleron, Pascal Denis. An End-to-End Approach for Full Bridging Resolution. CODI-CRAC 2021 - Shared-Task: Anaphora Resolution in Dialogues, Nov 2021, Punta Cana, Dominican Republic. pp.48-54. ⟨hal-03431313⟩
73 Consultations
88 Téléchargements
