Designing an Ecosystem Value Model Based on a Process Model – An Empirical Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ecosystems have both inter-organizational process models and corresponding business value models. Whereas process models show how actors interact in terms of message flows and the time-ordering of activities, business value models present what is exchanged of economic value and abstract away from operational activities and their control flows. As organizations usually have process models but not explicit value models, we propose to derive a value model from a process model. We hypothesize on how these two models conceptually correspond to each other. We employ a real-world case to verify our hypotheses and learn about the applicability of the proposed design.
500489_1_En_20_Chapter.pdf (602.15 Ko) Télécharger le fichier
hal-03434655 , version 1 (18-11-2021)
Paternité
Isaac Torres, Jaap Gordijn, Marcelo Fantinato, Joao Vieira. Designing an Ecosystem Value Model Based on a Process Model – An Empirical Approach. 13th IFIP WG 8.1 Working Conference on the Practice of Enterprise Modeling (PoEM 2020), Nov 2020, Riga, Latvia. pp.293-303, ⟨10.1007/978-3-030-63479-7_20⟩. ⟨hal-03434655⟩
29 Consultations
22 Téléchargements
