New interface
Conference papers
A Thesaurus Based Semantic Relation Extraction for Agricultural Corpora
Abstract : Semantic relations exist two concepts present in the text. Semantic relation extraction becomes an essential part of building an efficient Natural Language Processing (NLP) applications such as Question Answering (QA) and Information Retrieval (IR) system. Automatic semantic relation extraction from text increases the efficiency of these systems by aiding in retrieving more accurate information to the user query. In this research work, we have proposed a framework that extracts agricultural entities and finds the semantic relation exist between entities. Entity extraction is done using a Parts Of Speech (POS) tagger, Word Suffixes and Thesaurus without using any of the external domain-specific knowledge bases, such as Ontology and WordNet. Semantic relation exists between entities are done by using Multinomial Naïve Bayes (MNB) classifier. This paper extracts two entities, namely disease and treatment and focuses on two semantic relations namely “Cure” and “Prevent”. The “Cure” semantic relation expresses the remedial measure for the diseases that prevail in the crops, and the “Prevent” semantic relation shows the precautionary measures that could prevent the crop from being affected. The proposed approach has been trained with 2281 sentences and tested against 553 sentences and then evaluated using standard metrics.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-03434803
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Thursday, November 18, 2021 - 2:21:38 PM
Last modification on : Thursday, November 18, 2021 - 2:31:50 PM
Long-term archiving on: : Saturday, February 19, 2022 - 7:14:24 PM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2023-01-01
Please log in to resquest access to the document
Identifiers
Citation
R. Srinivasan, C. N. Subalalitha. A Thesaurus Based Semantic Relation Extraction for Agricultural Corpora. 3rd International Conference on Computational Intelligence in Data Science (ICCIDS), Feb 2020, Chennai, India. pp.99-111, ⟨10.1007/978-3-030-63467-4_8⟩. ⟨hal-03434803⟩
Share
Metrics
Record views
18
