Some factors of numbers of the form $b^n +/- 1$ found using ECM with new classes of curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
In this note, we list factors of numbers of the form $b^n+/-1$ found using GMP-ECM and new classes of elliptic curves.
factors.pdf (222.24 Ko) Télécharger le fichier
hal-03437714 , version 1 (20-11-2021)
hal-03437714 , version 2 (31-03-2022)
Paternité
  • HAL Id : hal-03437714 , version 2
François Morain. Some factors of numbers of the form $b^n +/- 1$ found using ECM with new classes of curves. 2022. ⟨hal-03437714v2⟩
168 Consultations
123 Téléchargements
