A Logic Based Approach to Finding Real Singularities of Implicit Ordinary Differential Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics in Computer Science Année : 2021
We discuss the effective computation of geometric singularities of implicit ordinary differential equations over the real numbers using methods from logic. Via the Vessiot theory of differential equations, geometric singularities can be characterised as points where the behaviour of a certain linear system of equations changes. These points can be discovered using a specifically adapted parametric generalisation of Gaussian elimination combined with heuristic simplification techniques and real quantifier elimination methods. We demonstrate the relevance and applicability of our approach with computational experiments using a prototypical implementation in Reduce .
Seiler2021_Article_ALogicBasedApproachToFindingRe.pdf (1.45 Mo) Télécharger le fichier
hal-03438167 , version 1 (21-11-2021)
Paternité
Werner M Seiler, Matthias Seiss, Thomas Sturm. A Logic Based Approach to Finding Real Singularities of Implicit Ordinary Differential Equations. Mathematics in Computer Science, 2021, 15 (2), pp.333-352. ⟨10.1007/s11786-020-00485-x⟩. ⟨hal-03438167⟩
28 Consultations
50 Téléchargements
