Neural Human Deformation Transfer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the problem of human deformation transfer, where the goal is to retarget poses between different characters. Traditional methods that tackle this problem assume a human pose model to be available and transfer poses between characters using this model. In this work, we take a different approach and transform the identity of a character into a new identity without modifying the character's pose. This offers the advantage of not having to define equivalences between 3D human poses, which is not straightforward as poses tend to change depending on the identity of the character performing them, and as their meaning is highly contextual. To achieve the deformation transfer, we propose a neural encoder-decoder architecture where only identity information is encoded and where the decoder is conditioned on the pose. We use pose independent representations, such as isometryinvariant shape characteristics, to represent identity features. Our model uses these features to supervise the prediction of offsets from the deformed pose to the result of the transfer. We show experimentally that our method outperforms state-of-the-art methods both quantitatively and qualitatively, and generalises better to poses not seen during training. We also introduce a fine-tuning step that allows to obtain competitive results for extreme identities, and allows to transfer simple clothing.
Neural Human Deformation Transfer.pdf (2 Mo) Télécharger le fichier
Neural Human Deformation Transfer.mp4 (11.47 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
hal-03440562 , version 1 (22-11-2021)
  • HAL Id : hal-03440562 , version 1
Jean Basset, Adnane Boukhayma, Stefanie Wuhrer, Franck Multon, Edmond Boyer. Neural Human Deformation Transfer. 3DV 2021 - 9th International Conference on 3D Vision, Dec 2021, Londres (on line event), United Kingdom. pp.1-12. ⟨hal-03440562⟩
283 Consultations
261 Téléchargements
