Visual Servoing in Autoencoder Latent Space: Supplementary material - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
This document provides additional information about [1], describing further experiments with Autoencoderbased visual servoing (AEVS), a method for visual servoing in the latent space of an autoencoder. Multiple experiments are described, both in a simulated environment and on a real robot. In this document, we first evaluate the impact of the network specification and dataset sizes on the visual servoing results. Then we conduct experiments to ascertain the applicability and transferability of the method to complex scenes.
RA_L_addendum-2.pdf (2.76 Mo) Télécharger le fichier
hal-03448667 , version 1 (25-11-2021)
  • HAL Id : hal-03448667 , version 1
Samuel Felton, Pascal Brault, Elisa Fromont, Eric Marchand. Visual Servoing in Autoencoder Latent Space: Supplementary material. 2021. ⟨hal-03448667⟩
137 Consultations
89 Téléchargements
