TSO-DSOs Stable Cost Allocation for the Joint Procurement of Flexibility: A Cooperative Game Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Smart Grid Année : 2022
In this paper, a transmission-distribution systems flexibility market is introduced, in which system operators (SOs)jointly procure flexibility from different systems to meet their needs (balancing and congestion management) using a commonmarket. This common market is, then, formulated as a cooperative game aiming at identifying a stable and efficient split ofcosts of the jointly procured flexibility among the participating SOs to incentivize their cooperation. The non-emptiness of thecore of this game is then mathematically proven, implying the stability of the game and the naturally-arising incentive forcooperation among the SOs. Several cost allocation mechanisms are then introduced, while characterizing their mathematicalproperties. Numerical results focusing on an interconnected system (composed of the IEEE 14-bus transmission systemand the Matpower 18-bus, 69-bus, and 141-bus distributions systems) showcase the cooperation-induced reduction in systemwideflexibility procurement costs, and identifies the varying costs borne by different SOs under various cost allocations methods.
Coordinet_Cooperative_game.pdf (1.51 Mo) Télécharger le fichier
hal-03449923 , version 1 (25-11-2021)
hal-03449923 , version 2 (18-02-2022)
hal-03449923 , version 3 (08-04-2022)
Anibal Sanjab, Hélène Le Cadre, Yuting Mou. TSO-DSOs Stable Cost Allocation for the Joint Procurement of Flexibility: A Cooperative Game Approach. IEEE Transactions on Smart Grid, In press, ⟨10.1109/tsg.2022.3166350⟩. ⟨hal-03449923v3⟩
192 Consultations
152 Téléchargements
