Dual Mesh Convolutional Networks for Human Shape Correspondence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Convolutional networks have been extremely successful for regular data structures such as 2D images and 3D voxel grids. The transposition to meshes is, however, not straightforward due to their irregular structure. We explore how the dual, face-based representation of triangular meshes can be leveraged as a data structure for graph convolutional networks. In the dual mesh, each node (face) has a fixed number of neighbors, which makes the networks less susceptible to overfitting on the mesh topology, and also allows the use of input features that are naturally defined over faces, such as surface normals and face areas. We evaluate the dual approach on the shape correspondence task on the Faust human shape dataset and variants of it with different mesh topologies. Our experiments show that results of graph convolutional networks improve when defined over the dual rather than primal mesh. Moreover, our models that explicitly leverage the neighborhood regularity of dual meshes allow improving results further while being more robust to changes in the mesh topology.
3DV_DualConv.pdf (24.37 Mo) Télécharger le fichier
hal-03450573 , version 1 (26-11-2021)
  • HAL Id : hal-03450573 , version 1
Nitika Verma, Adnane Boukhayma, Edmond Boyer, Jakob Verbeek. Dual Mesh Convolutional Networks for Human Shape Correspondence. 3DV 2021 - International Conference on 3D Vision, Dec 2021, Surrey, United Kingdom. pp.1-10. ⟨hal-03450573⟩
127 Consultations
54 Téléchargements
