Link-Based Cluster Ensemble Method for Improved Meta-clustering Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ensemble clustering has become a hot research field in intelligent information processing and machine learning. Although significant progress has been made in recent years, there are still two challenging issues in the current ensemble clustering research. First of all, most ensemble clustering algorithms tend to explore similarity at the level of object but lack the ability to explore information at the level of cluster. Secondly, many ensemble clustering algorithms only focus on the direct relationship, while ignoring the indirect relationship between clusters. In order to solve these two problems, a link-based meta-clustering algorithm (L-MCLA) have been proposed in this paper. A series of experiment results demonstrate that the proposed algorithm not only produces better clustering effect but is also less influenced by different ensemble sizes.
498234_1_En_2_Chapter.pdf (619.44 Ko) Télécharger le fichier
hal-03456974 , version 1 (30-11-2021)
Paternité
Changlong Shao, Shifei Ding. Link-Based Cluster Ensemble Method for Improved Meta-clustering Algorithm. 11th International Conference on Intelligent Information Processing (IIP), Jul 2020, Hangzhou, China. pp.14-25, ⟨10.1007/978-3-030-46931-3_2⟩. ⟨hal-03456974⟩
42 Consultations
23 Téléchargements
