Environmental Parameters Analysis and Power Prediction for Photovoltaic Power Generation Based on Ensembles of Decision Trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Due to the influence of solar irradiation, temperature and other environmental factors, the output power of photovoltaic power generation has great randomness and randomness discontinuity. In this paper, a method for analyzing environment data related photovoltaic power generation based on ensembles of decision trees algorithm is studied. Firstly, the characteristics of environmental factors of photovoltaic power generation are analyzed by K-means clustering. And then the corresponding cluster label is assigned. Furthermore, the Radom Forests is combined to build a model. Finally, the method is validated by given data above from a real project. The results show that the proposed method can provide reference for the forecasting of photovoltaic power.
498234_1_En_8_Chapter.pdf (567.73 Ko) Télécharger le fichier
hal-03456980 , version 1 (30-11-2021)
Paternité
Shuai Zhang, Hongwei Dai, Aizhou Yang, Zhongzhi Shi. Environmental Parameters Analysis and Power Prediction for Photovoltaic Power Generation Based on Ensembles of Decision Trees. 11th International Conference on Intelligent Information Processing (IIP), Jul 2020, Hangzhou, China. pp.78-85, ⟨10.1007/978-3-030-46931-3_8⟩. ⟨hal-03456980⟩
19 Consultations
24 Téléchargements
