Phase Plane Analysis of Traffic Phenomena with Different Input and Output Conditions - Archive ouverte HAL Access content directly
Conference Papers Year : 2020
(1) , (1) , (1) , (2) , (1)
1
2
Wenhuan Ai
  • Function : Author
  • PersonId : 1118831
Yuhang Su
  • Function : Author
  • PersonId : 1118833
Tao Xing
  • Function : Author
  • PersonId : 1118832
Dawei Liu
  • Function : Author
  • PersonId : 1118834
Huifang Ma
  • Function : Author
  • PersonId : 1118835
In this paper, the traffic flow problem is converted into a system stability problem through variable substitution and a phase plane analysis method is presented for analyzing the complex nonlinear traffic phenomena. This method matches traffic congestion with the unstable system. So these theories and methods of stability can be applied directly to solve the traffic problem. Based on an anisotropic continuum model developed by Gupta and Katiyar (GK model), this paper uses this new method to describe various nonlinear phenomena due to different input and output conditions on ramps which were rarely studied in the past. The results show that the traffic phenomena described by the new method is consistent with that described by traditional methods. Moreover, the phase plane diagram highlights the unstable traffic phenomena we are chiefly concerned about and describes the variation of density or velocity with time or sections more clearly.
498234_1_En_20_Chapter.pdf (453.14 Ko) Télécharger le fichier
Dates and versions
hal-03456987 , version 1 (30-11-2021)
Attribution - CC BY 4.0
Identifiers
Cite
Wenhuan Ai, Yuhang Su, Tao Xing, Dawei Liu, Huifang Ma. Phase Plane Analysis of Traffic Phenomena with Different Input and Output Conditions. 11th International Conference on Intelligent Information Processing (IIP), Jul 2020, Hangzhou, China. pp.213-221, ⟨10.1007/978-3-030-46931-3_20⟩. ⟨hal-03456987⟩
14 View
0 Download
Share
