Approximate analytical coefficient of restitution formulation for single bead impact with external load, using nonlinear visco-elastic models - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 2021
(1) , (1) , (1)
1
This work is largely concerned with the calculation of an approximate coefficient of restitution (CoR) associated with nonlinear spring/dashpot models, when a constant external load acts upon the colliding body. Some of the main applications concern well known visco-elastic models such as Kuwabara-Kono, Simon-Hunt-Crosseley, Tsuji-Tanaka-Ishida, etc, however the proposed approach to a very wide class of nonlinear visco-elastic contact models. It is shown that suitable expansions allow to derive a computable expression which provides accurate predictions in a valuable range of external loads and viscosity coefficients.
COR_Computation_extended_report.pdf (6.93 Mo) Télécharger le fichier
Dates and versions
hal-03462750 , version 1 (02-12-2021)
Identifiers
  • HAL Id : hal-03462750 , version 1
Cite
Abhishek Chatterjee, Guillaume James, Bernard Brogliato. Approximate analytical coefficient of restitution formulation for single bead impact with external load, using nonlinear visco-elastic models. [Research Report] INRIA Grenoble - Rhone-Alpes. 2021, pp.1-50. ⟨hal-03462750⟩
95 View
34 Download
Share
