Leveraging Passage Retrieval with Generative Models for Open Domain Question Answering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Generative models for open domain question answering have proven to be competitive, without resorting to external knowledge. While promising, this approach requires to use models with billions of parameters, which are expensive to train and query. In this paper, we investigate how much these models can benefit from retrieving text passages, potentially containing evidence. We obtain state-of-the-art results on the Natural Questions and Triv-iaQA open benchmarks. Interestingly, we observe that the performance of this method significantly improves when increasing the number of retrieved passages. This is evidence that sequence-to-sequence models offers a flexible framework to efficiently aggregate and combine evidence from multiple passages.
Leveraging_Passage_Retrieval_with_Generative_Models__EACL_ (12).pdf (279.84 Ko) Télécharger le fichier
hal-03463108 , version 1 (02-12-2021)
Gautier Izacard, Edouard Grave. Leveraging Passage Retrieval with Generative Models for Open Domain Question Answering. EACL 2021 - 16th Conference of the European Chapter of the Association for Computational Linguistics, Apr 2021, Kiev, Ukraine. pp.874-880, ⟨10.18653/v1/2021.eacl-main.74⟩. ⟨hal-03463108⟩
140 Consultations
121 Téléchargements
