High-order sliding mode control of a doubly salient permanent magnet machine driving marine current turbine - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Ocean Engineering and Science Année : 2021
This is a PDF file of an article that has undergone enhancements after acceptance, such as the addition of a cover page and metadata, and formatting for readability, but it is not yet the definitive version of record. This version will undergo additional copyediting, typesetting and review before it is published in its final form, but we are providing this version to give early visibility of the article. Please note that, during the production process, errors may be discovered which could affect the content, and all legal disclaimers that apply to the journal pertain.
High-order_sliding_mode_control_of_a_doubly_salien.pdf (1.71 Mo) Télécharger le fichier
hal-03463388 , version 1 (02-12-2021)
Hao Chen, Shifeng Tang, Jingang Han, Tianhao Tang, Nadia Aït-Ahmed, et al.. High-order sliding mode control of a doubly salient permanent magnet machine driving marine current turbine. Journal of Ocean Engineering and Science, 2021, 6 (1), pp.12-20. ⟨10.1016/j.joes.2020.04.001⟩. ⟨hal-03463388⟩
53 Consultations
38 Téléchargements
