Distilling Knowledge from Reader to Retriever for Question Answering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The task of information retrieval is an important component of many natural language processing systems, such as open domain question answering. While traditional methods were based on hand-crafted features, continuous representations based on neural networks recently obtained competitive results. A challenge of using such methods is to obtain supervised data to train the retriever model, corresponding to pairs of query and support documents. In this paper, we propose a technique to learn retriever models for downstream tasks, inspired by knowledge distillation, and which does not require annotated pairs of query and documents. Our approach leverages attention scores of a reader model, used to solve the task based on retrieved documents, to obtain synthetic labels for the retriever. We evaluate our method on question answering, obtaining state-of-the-art results.
Distilling_Reader_Retriever.pdf (222.95 Ko) Télécharger le fichier
hal-03463398 , version 1 (02-12-2021)
  • HAL Id : hal-03463398 , version 1
Gautier Izacard, Edouard Grave. Distilling Knowledge from Reader to Retriever for Question Answering. ICLR 2021 - 9th International Conference on Learning Representations, May 2021, Vienna, Austria. ⟨hal-03463398⟩
60 Consultations
227 Téléchargements
