Zero Knowledge Arguments for Verifiable Sampling
In privacy-preserving machine learning, it is less obvious to verify correct behavior of participants because they are not supposed to reveal their inputs in cleartext to other participants. It is hence important to make federated machine learning robust against data poisoning and related attacks. While input data can be related to a distributed ledger (blockchain), a less studied input is formed by the random sampling parties perform. In this paper, we describe strategies based on zero knowledge proofs to allow parties to prove they perform sampling (and other computations) correctly. We sketch a number of alternative ways to implement our idea and provide some preliminary experimental results.
