Fast Guaranteed Drawing of High Degree Algebraic Curves - Archive ouverte HAL Access content directly
Preprints, Working Papers, ... Year :
We address the problem of computing a guaranteed drawing of high resolution of a plane curve defined by a bivariate polynomial equation P (x, y) = 0. The drawing is a subset of pixels defined on a grid of a given resolution with the guarantee that the pixels enclose all the parts of the curve that intersect the grid. Our main contribution is to use a non-uniform grid based on the Chebyshev nodes to take advantage of multipoint evaluation techniques via the Discrete Cosine Transform. We propose two new algorithms that compute guaranteed drawings and compare them experimentally on several classes of high degree polynomials. Notably, one of those approaches is faster than state-of-the-art drawing software, even when they are not guaranteed.
test.pdf (2.07 Mo) Télécharger le fichier
Dates and versions
hal-03465123 , version 1 (03-12-2021)
Identifiers
  • HAL Id : hal-03465123 , version 1
Cite
Nuwan Herath Mudiyanselage, Guillaume Moroz, Marc Pouget. Fast Guaranteed Drawing of High Degree Algebraic Curves. 2021. ⟨hal-03465123⟩
79 View
72 Download
Share
