An accelerated level-set method for inverse scattering problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Imaging Sciences Année : 2022
We propose a rapid and robust iterative algorithm to solve inverse acoustic scattering problems formulated as a PDE constrained shape optimization problem. We use a level-set method to represent the obstacle geometry and propose a new scheme for updating the geometry based on an adaptation of accelerated gradient descent methods. The resulting algorithm aims at reducing the number of iterations and improving the accuracy of reconstructions. To cope with regularization issues, we propose a smoothing to the shape gradient using a single layer potential associated with ik where k is the wave number. Numerical experiments are given for several data types (full aperture, backscattering, phaseless, multiple frequencies) and show that our method outperforms a non accelerated approach in terms of convergence speed, accuracy and sensitivity to initial guesses.
ShapeOpt-Nesterov-InvSca.pdf (1.23 Mo) Télécharger le fichier
hal-03465136 , version 1 (03-12-2021)
hal-03465136 , version 2 (03-02-2023)
Lorenzo Audibert, Houssem Haddar, Xiaoli Liu. An accelerated level-set method for inverse scattering problems. SIAM Journal on Imaging Sciences, 2022, 15 (3), pp.1576-1600. ⟨10.1137/21M1457783⟩. ⟨hal-03465136v2⟩
207 Consultations
212 Téléchargements
