A verification framework for secure machine learning
We propose a programming and verification framework to help developers build distributed software applications using composite homomorphic encryption (and secure multi-party computation) protocols, and implement secure machine learning and classification over private data. With our framework, a developer can prove that the application code is functionally correct, that it correctly composes the various cryptographic schemes it uses, and that it does not accidentally leak any secrets (via side-channels, for example.) Our end-to-end solution results in verified and efficient implementations of state-of-the-art secure privacy-preserving learning and classification techniques.
