The Regular Languages of Wire Linear AC 0 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Michaël Cadilhac
  • Fonction : Auteur
  • PersonId : 1119330
Charles Paperman
  • Fonction : Auteur
  • PersonId : 1119331
In this paper, the regular languages of wire linear AC 0 are characterized as the languages expressible in the two-variable fragment of first-order logic with regular predicates, FO 2 [reg]. Additionally, they are characterized as the languages recognized by the algebraic class QLDA. The class is shown to be decidable and examples of languages in and outside of it are presented.
main.pdf (682.63 Ko) Télécharger le fichier
hal-03466451 , version 1 (05-12-2021)
hal-03466451 , version 2 (08-12-2021)
  • HAL Id : hal-03466451 , version 2
Michaël Cadilhac, Charles Paperman. The Regular Languages of Wire Linear AC 0. 2021. ⟨hal-03466451v2⟩
57 Consultations
100 Téléchargements
