Corinne, a Tool for Choreography Automata
Choreography automata are a model of choreographies envisaging high-level views of the behaviour of communicating systems as finite-state automata. The behaviour of each participant of a choreography can be obtained via a projection operation from a choreography automaton. The system of participants obtained by projection is well-behaved if the choreography automaton satisfies some well-formedness conditions. We present Corinne, a tool allowing one to render, compute projections of and compose choreography automata, as well as to check well-formedness conditions.
