Off-the-grid variational sparse spike recovery: methods and algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Imaging Année : 2021
Bastien Laville
Laure Blanc-Féraud
Gilles Aubert
  • Fonction : Auteur
  • PersonId : 949451
Gridless sparse spike reconstruction is a rather new research field with significant results for the super-resolution problem, where we want to retrieve fine-scale details from a noisy and filtered acquisition. To tackle this problem, we are interested in optimisation under some prior, typically the sparsity i.e., the source is composed of spikes. Following the seminal work on the generalised LASSO for measures called the Beurling-Lasso (BLASSO), we will give a review on the chief theoretical and numerical breakthrough of the off-the-grid inverse problem, as we illustrate its usefulness to the super-resolution problem in Single Molecule Localisation Microscopy (SMLM) through new reconstruction metrics and tests on synthetic and real SMLM data we performed for this review.
Off_the_grid_review_Journal_of_Imaging_2021.pdf (3.28 Mo) Télécharger le fichier
hal-03468412 , version 1 (07-12-2021)
Bastien Laville, Laure Blanc-Féraud, Gilles Aubert. Off-the-grid variational sparse spike recovery: methods and algorithms. Journal of Imaging, 2021, 7 (12), pp.266. ⟨10.3390/jimaging7120266⟩. ⟨hal-03468412⟩
116 Consultations
85 Téléchargements
