Offline Reinforcement Learning with Pseudometric Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Offline Reinforcement Learning methods seek to learn a policy from logged transitions of an environment, without any interaction. In the presence of function approximation, and under the assumption of limited coverage of the state-action space of the environment, it is necessary to enforce the policy to visit state-action pairs close to the support of logged transitions. In this work, we propose an iterative procedure to learn a pseudometric (closely related to bisimulation metrics) from logged transitions, and use it to define this notion of closeness. We show its convergence and extend it to the function approximation setting. We then use this pseudometric to define a new lookup based bonus in an actor-critic algorithm: PLOFF. This bonus encourages the actor to stay close, in terms of the defined pseudometric, to the support of logged transitions. Finally, we evaluate the method on hand manipulation and locomotion tasks.
hal-03468847 , version 1 (07-12-2021)
Robert Dadashi, Shideh Rezaeifar, Nino Vieillard, Léonard Hussenot, Olivier Pietquin, et al.. Offline Reinforcement Learning with Pseudometric Learning. ICML 2021 - 38th International Conference on Machine Learning, Jun 2021, virtual, France. ⟨hal-03468847⟩
41 Consultations
0 Téléchargements
