Robust and Efficient Delaunay Triangulations of Points on Or Close to a Sphere - Archive ouverte HAL Access content directly
Conference Papers Year : 2010
We propose two ways to compute the Delaunay triangulation of points on a sphere, or of rounded points close to a sphere, both based on the classic incremental algorithm initially designed for the plane. We use the so-called space of circles as mathematical background for this work. We present a fully robust implementation built upon existing generic algorithms provided by the Cgal library. The efficiency of the implementation is established by benchmarks.
SEA10.pdf (503.34 Ko) Télécharger le fichier
Format : Figure, Image
Dates and versions
hal-03469649 , version 1 (07-12-2021)
Identifiers
  • HAL Id : hal-03469649 , version 1
Cite
Manuel Caroli, Pedro M M de Castro, Sébastien Loriot, Olivier Rouiller, Monique Teillaud, et al.. Robust and Efficient Delaunay Triangulations of Points on Or Close to a Sphere. Symposium on Experimental Algorithms, 2010, Naples, Italy. pp.462-473. ⟨hal-03469649⟩
Collections
INRIA INRIA2 ANR
11 View
105 Download
Share
