Daily peak electrical load forecasting with a multi-resolution approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Forecasting Année : 2022
In the context of smart grids and load balancing, daily peak load forecasting has become a critical activity for stakeholders of the energy industry. An understanding of peak magnitude and timing is paramount for the implementation of smart grid strategies such as peak shaving. The modelling approach proposed in this paper leverages high-resolution and low-resolution information to forecast daily peak demand size and timing. The resulting multi-resolution modelling framework can be adapted to different model classes. The key contributions of this paper are a) a general and formal introduction to the multi-resolution modelling approach, b) a discussion on modelling approaches at different resolutions implemented via Generalised Additive Models and Neural Networks and c) experimental results on real data from the UK electricity market. The results confirm that the predictive performance of the proposed modelling approach is competitive with that of low-and high-resolution alternatives.
Preprint.pdf (1.07 Mo) Télécharger le fichier
hal-03469721 , version 1 (07-12-2021)
  • HAL Id : hal-03469721 , version 1
Yvenn Amara-Ouali, Matteo Fasiolo, Yannig Goude, Hui Yan. Daily peak electrical load forecasting with a multi-resolution approach. International Journal of Forecasting, 2022. ⟨hal-03469721⟩
78 Consultations
229 Téléchargements
