Seismic waves in medium with poroelastic/elastic interfaces: a two-dimensional P-SV finite-difference modelling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Geophysical Journal International Année : 2022
We present a new methodology of the finite-difference (FD) modelling of seismic wave propagation in a strongly heterogeneous medium composed of poroelastic (P) and (strictly) elastic (E) parts. The medium can include P/P, P/E and E/E material interfaces of arbitrary shapes. The poroelastic part can be with (i) zero resistive friction, (ii) non-zero constant resistive friction or (iii) JKD model of the frequency-dependent permeability and resistive friction. Our FD scheme is capable of subcell resolution: a material interface can have an arbitrary position in the spatial grid. The scheme keeps computational efficiency of the scheme for a smoothly and weakly heterogeneous medium (medium without material interfaces). Numerical tests against independent analytical, semi-analytical and spectral-element methods prove the efficiency and accuracy of our FD modelling. In numerical examples, we indicate effect of the P/E interfaces for the poroelastic medium with a constant resistive friction and medium with the JKD model of the frequency-dependent permeability and resistive friction. We address the 2-D P-SV problem. The approach can be readily extended to the 3-D problem.
Fichier non déposé
hal-03471065 , version 1 (08-12-2021)
David Gregor, Peter Moczo, Jozef Kristek, Arnaud Mesgouez, Gaëlle Lefeuve-Mesgouez, et al.. Seismic waves in medium with poroelastic/elastic interfaces: a two-dimensional P-SV finite-difference modelling. Geophysical Journal International, 2022, 228 (1), pp.551-588. ⟨10.1093/gji/ggab357⟩. ⟨hal-03471065⟩
65 Consultations
0 Téléchargements
