Dissipativity analysis of negative resistance circuits - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2022
This paper deals with the analysis of nonlinear circuits that interconnect passive elements (capacitors, inductors, and resistors) with nonlinear resistors exhibiting a range of negative resistance. Active elements are necessary to design physical circuits that switch and oscillate. We generalize the classical passivity theory of circuit analysis to develop a port interconnection theory for such non-equilibrium behaviors. The approach closely mimics the classical methodology of (incremental) dissipativity theory, but with dissipation inequalities that combine signed storage functions and signed supply rates to account for the port interconnection of passive and active elements.
S0005109821005379.pdf (311.34 Ko) Télécharger le fichier
hal-03472776 , version 1 (08-01-2024)
Paternité - Pas d'utilisation commerciale
Felix Miranda-Villatoro, Fulvio Forni, Rodolphe Sepulchre. Dissipativity analysis of negative resistance circuits. Automatica, 2022, 136, pp.110011:1-8. ⟨10.1016/j.automatica.2021.110011⟩. ⟨hal-03472776⟩
60 Consultations
6 Téléchargements
