BioImageIT: Open-source framework for integration of image data-management with analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nature Methods Année : 2022
Open science and FAIR principles have become major topics in the field of bioimaging. This is due to both new data acquisition technologies that generate large datasets, and new analysis approaches that automate data mining with high accuracy. Nevertheless, data are rarely shared and rigorously annotated because it requires a lot of manual and tedious management tasks and software packaging. We present BioImageIT, an open-source framework for integrating data management according to FAIR principles with data processing.
BioImageIT_Manuscript_07122021_merge.pdf (948.89 Ko) Télécharger le fichier
hal-03474512 , version 1 (10-12-2021)
Paternité
Sylvain Prigent, Cesar Augusto Valades-Cruz, Ludovic Leconte, Léo Maury, Jean Salamero, et al.. BioImageIT: Open-source framework for integration of image data-management with analysis. Nature Methods, 2022, 19, pp.1328-1330. ⟨10.1038/s41592-022-01642-9⟩. ⟨hal-03474512⟩
181 Consultations
219 Téléchargements
