Modular-proximal gradient algorithms in variable exponent Lebesgue spaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Scientific Computing Année : 2022
Luca Calatroni
We consider structured optimisation problems defined in terms of the sum of a smooth and convex function, and a proper, l.s.c., convex (typically non-smooth) one in reflexive variable exponent Lebesgue spaces $L^{p(.)}(\Omega)$. Due to their intrinsic space-variant properties, such spaces can be naturally used as solution space and combined with space-variant functionals for the solution of ill-posed inverse problems. For this purpose, we propose and analyse two instances (primal and dual) of proximal gradient algorithms in $L^{p(.)}(\Omega)$., where the proximal step, rather than depending on the natural (non-separable) $L^{p(.)}(\Omega)$. norm, is defined in terms of its modular function, which, thanks to its separability, allows for the efficient computation of algorithmic iterates. Convergence in function values is proved for both algorithms, with convergence rates depending on problem/space smoothness. To show the effectiveness of the proposed modelling, some numerical tests highlighting the flexibility of the space $L^{p(.)}(\Omega)$. are shown for exemplar deconvolution and mixed noise removal problems. Finally, a numerical verification on the convergence speed and computational costs of both algorithms in comparison with analogous ones defined in standard $L^{p(.)}(\Omega)$. spaces is presented.
ARXIV_modular_proximal_algorithm.pdf (2.72 Mo) Télécharger le fichier
hal-03476299 , version 1 (12-12-2021)
  • HAL Id : hal-03476299 , version 1
Marta Lazzaretti, Luca Calatroni, Claudio Estatico. Modular-proximal gradient algorithms in variable exponent Lebesgue spaces. SIAM Journal on Scientific Computing, 2022. ⟨hal-03476299⟩
64 Consultations
38 Téléchargements
