Efficient Soft Error Vulnerability Analysis Using Non-intrusive Fault Injection Techniques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Electronic computing systems are integrating modern multicore processors and GPUs aiming to perform complex software stacks in different life-critical systems, including health devices and emerging self-driving cars. Such systems are expected to experience at least one soft error per day in the near future, which may lead to life-threatening failures. To prevent these failures, critical system must be tested and verified while under realistic workloads. This paper presents four novel non-intrusive fault injection techniques that enable full fault injection control and inspection of multicore systems behavior in the presence of faults. Proposed techniques were integrated into a fault injection framework and verified through a real automotive case study with up to 43 billions instructions. Results show that compared to traditional methods, the new techniques can increase the efficiency of fault injection campaigns during early development phase by 32.28%.
501403_1_En_6_Chapter.pdf (1.53 Mo) Télécharger le fichier
hal-03476605 , version 1 (13-12-2021)
Paternité
Vitor Bandeira, Felipe Rosa, Ricardo Reis, Luciano Ost. Efficient Soft Error Vulnerability Analysis Using Non-intrusive Fault Injection Techniques. 27th IFIP/IEEE International Conference on Very Large Scale Integration - System on a Chip (VLSI-SoC), Oct 2019, Cusco, Peru. pp.115-137, ⟨10.1007/978-3-030-53273-4_6⟩. ⟨hal-03476605⟩
31 Consultations
51 Téléchargements
