Graph Diffusion & PCA Framework for Semi-supervised Learning
A novel framework called Graph Diffusion & PCA (GDPCA) is proposed in the context of semi-supervised learning on graph structured data. It combines a modified Principal Component Analysis with the classical supervised loss and Laplacian regularization, thus handling the case where the adjacency matrix is sparse and avoiding the curse of dimensionality. Our framework can be applied to non-graph datasets as well, such as images by constructing similarity graph. GDPCA improves node classification by enriching the local graph structure by node covariance. We demonstrate the performance of GDPCA in experiments on citation networks and images, and we show that GDPCA compares favourably with the best state-of-the-art algorithms and has significantly lower computational complexity.
