A machine learning-based methodology for multi-parametric solution of chemical processes operation optimization under uncertainty - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Chemical Engineering Journal Année : 2021
S1385894721032137.pdf (2.53 Mo) Télécharger le fichier
hal-03480576 , version 1 (16-10-2023)
Paternité - Pas d'utilisation commerciale - Pas de modification
Ahmed Shokry, Sergio Medina-González, Piero Baraldi, Enrico Zio, Eric Moulines, et al.. A machine learning-based methodology for multi-parametric solution of chemical processes operation optimization under uncertainty. Chemical Engineering Journal, 2021, 425, pp.131632. ⟨10.1016/j.cej.2021.131632⟩. ⟨hal-03480576⟩
127 Consultations
9 Téléchargements
