Reachability games with relaxed energy constraints
We study games with reachability objectives under energy constraints. We first prove that under strict energy constraints (either only lower-bound constraint or interval constraint), those games are LOGSPACE-equivalent to energy games with the same energy constraints but without reachability objective (i.e., for infinite runs). We then consider two relaxations of the upper-bound constraints (while keeping the lower-bound constraint strict): in the first one, called weak upper bound, the upper bound is absorbing, i.e., when the upper bound is reached, the extra energy is not stored;
in the second one, we~allow for temporary violations of the upper bound, imposing limits on the number or on the amount of violations.
Théorie et langage formel [cs.FL]
