Accurate calculation of Euclidean Norms using Double-word arithmetic
We consider the computation of the Euclidean (or L2) norm of an n-dimensional vector in floating-point arithmetic. We review the classical solutions used to avoid spurious overflow or underflow and/or to obtain very accurate results. We modify a recently published algorithm (that uses double-word arithmetic) to allow for a very accurate solution, free of spurious overflows and underflows. To that purpose, we use a double-word square-root algorithm of which we provide a tight error analysis. The returned L2 norm will be within very slightly more than 0.5 ulp from the exact result, which means that we will almost always provide correct rounding.
NormsandDW HaLV2.pdf (771.99 Ko)
Télécharger le fichier
C_and_Julia.zip (126.7 Ko)
en_sqrt_dw_coq.tar.gz (145.81 Ko)
