Approximate Computing for DNN - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
HiPEAC_approxDL.pdf (5.08 Mo) Télécharger le fichier
hal-03494932 , version 1 (20-12-2021)
  • HAL Id : hal-03494932 , version 1
Olivier Sentieys. Approximate Computing for DNN: Improving performance and energy efficiency of deep-learning hardware accelerators with controlled arithmetic approximations. CSW 2021 - HiPEAC Computing Systems Week, Oct 2021, Lyon, France. ⟨hal-03494932⟩
24 Consultations
98 Téléchargements
