On convergence conditions for generalized Persidskii systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2021
The convergence conditions for a class of generalized Persidskii systems and their discretized dynamics are introduced, which can be checked through linear (matrix) inequalities. The case of almost periodic convergence for this class of systems with almost periodic input is also studied. The proposed results are applied to a Lotka-Volterra model and opinion dynamics.
Convergence_IJRNC.pdf (1.17 Mo) Télécharger le fichier
hal-03495478 , version 1 (20-12-2021)
  • HAL Id : hal-03495478 , version 1
Wenjie Mei, Denis Efimov, Rosane Ushirobira, Alexander Aleksandrov. On convergence conditions for generalized Persidskii systems. International Journal of Robust and Nonlinear Control, In press. ⟨hal-03495478⟩
26 Consultations
69 Téléchargements
