State observation in microbial consortia: A case study on a synthetic producer‐cleaner consortium - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2021
In this article, the problem of state estimation of a microbial consortium is discussed. This microbial consortium is composed of two strains, called producer and cleaner, in continuous culture. The producer strain grows by consuming glucose, while the cleaner grows by consuming the acetate excreted by the producer and toxifies the environment. Considering two available measurements, the total biomass and a fluorescent reporter, an observability analysis is cast and state estimators are proposed for each state component of this system. Although the system is shown to be detectable using solely the total biomass as measurement, the advantage of measuring the fluorescent reporter on the observer design is highlighted. A numerical experiment illustrates the methodology.
Fichier non déposé
hal-03495889 , version 1 (20-12-2021)
Alex dos Reis de Souza, Denis Efimov, Andrey Polyakov, Jean-Luc Gouzé, Eugenio Cinquemani. State observation in microbial consortia: A case study on a synthetic producer‐cleaner consortium. International Journal of Robust and Nonlinear Control, 2021, pp.1-12. ⟨10.1002/rnc.5945⟩. ⟨hal-03495889⟩
100 Consultations
0 Téléchargements
