Circular pattern matching with k mismatches - Archive ouverte HAL Access content directly
Journal Articles Journal of Computer and System Sciences Year : 2021
(1, 2) , (3, 2) , (4, 5, 2) , (2) , (2) , (2) , (2) , (2)
1
2
3
4
5
The k-mismatch problem consists in computing the Hamming distance between a pattern P of length m and every length-m substring of a text T of length n, if this distance is no more than k. In many real-world applications, any cyclic rotation of P is a relevant pattern, and thus one is interested in computing the minimal distance of every length-m substring of T and any cyclic rotation of P. This is the circular pattern matching with k mismatches (k-CPM) problem. A multitude of papers have been devoted to solving this problem but, to the best of our knowledge, only average-case upper bounds are known. In this paper, we present the first non-trivial worst-case upper bounds for the k-CPM problem. Specifically, we show an O(nk)-time algorithm and an O(n + n m k 4)-time algorithm. The latter algorithm applies in an extended way a technique that was very recently developed for the k-mismatch problem [Bringmann et al., SODA 2019]. A preliminary version of this work appeared at FCT 2019. In this version we improve the time complexity of the main algorithm from O(n + n m k 5) to O(n + n m k 4).
1907.01815.pdf (689.86 Ko) Télécharger le fichier
Dates and versions
hal-03498339 , version 1 (21-12-2021)
Identifiers
Cite
Panagiotis Charalampopoulos, Tomasz Kociumaka, Solon P Pissis, Jakub Radoszewski, Wojciech Rytter, et al.. Circular pattern matching with k mismatches. Journal of Computer and System Sciences, 2021, 115, pp.73-85. ⟨10.1016/j.jcss.2020.07.003⟩. ⟨hal-03498339⟩
Collections
INRIA INRIA2
11 View
52 Download
Share
