Local improvement algorithms for a path packing problem: A performance analysis based on linear programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Operations Research Letters Année : 2021
Given a graph, we wish to find a maximum number of vertex-disjoint paths of length 2. We propose a series of local improvement algorithms for this problem, and present a linear-programming based method for analyzing their performance.
Local_improvement_algorithms_for_a_path_packing_pr.pdf (399.82 Ko) Télécharger le fichier
hal-03498424 , version 1 (21-12-2021)
Koen M J de Bontridder, Bjarni V Halldórsson, Magnús M Halldórsson, Cor a J Hurkens, Jan Karel Lenstra, et al.. Local improvement algorithms for a path packing problem: A performance analysis based on linear programming. Operations Research Letters, 2021, 49 (1), pp.62-68. ⟨10.1016/j.orl.2020.11.005⟩. ⟨hal-03498424⟩
Collections
INRIA INRIA2
15 Consultations
36 Téléchargements
