Cracking the Stateful Nut - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bana and Comon have proposed a logical approach to proving protocols in the computational model, which they call the Computationally Complete Symbolic Attacker (CCSA). The proof assistant Squirrel implements a verification technique that elaborates on this approach, building on a meta-logic over the CCSA base logic. In this paper, we show that this meta-logic can naturally be extended to handle protocols with mutable states (key updates, counters, etc.) and we extend \Squirrel's proof system to be able to express the complex proof arguments that are sometimes required for these protocols. Our theoretical contributions have been implemented in Squirrel and validated on a number of case studies, including a proof of the YubiKey and YubiHSM protocols.
main.pdf (516.04 Ko) Télécharger le fichier
hal-03500056 , version 1 (17-02-2022)
  • HAL Id : hal-03500056 , version 1
David Baelde, Stéphanie Delaune, Adrien Koutsos, Solène Moreau. Cracking the Stateful Nut: Computational Proofs of Stateful Security Protocols using the Squirrel Proof Assistant. CSF 2022 - 35th IEEE Computer Security Foundations Symposium, Aug 2022, Haifa, Israel. ⟨hal-03500056⟩
340 Consultations
178 Téléchargements
