Subspace Detours Meet Gromov-Wasserstein - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Algorithms Année : 2021
In the context of optimal transport (OT) methods, the subspace detour approach was recently proposed by Muzellec and Cuturi. It consists of first finding an optimal plan between the measures projected on a wisely chosen subspace and then completing it in a nearly optimal transport plan on the whole space. The contribution of this paper is to extend this category of methods to the Gromov–Wasserstein problem, which is a particular type of OT distance involving the specific geometry of each distribution. After deriving the associated formalism and properties, we give an experimental illustration on a shape matching problem. We also discuss a specific cost for which we can show connections with the Knothe–Rosenblatt rearrangement.
2110.10932.pdf (2.36 Mo) Télécharger le fichier
hal-03500536 , version 1 (11-01-2024)
Clément Bonet, Titouan Vayer, Nicolas Courty, François Septier, Lucas Drumetz. Subspace Detours Meet Gromov-Wasserstein. Algorithms, 2021, Special Issue Optimal Transport: Algorithms and Applications, 14 (12), pp.366. ⟨10.3390/a14120366⟩. ⟨hal-03500536⟩
138 Consultations
14 Téléchargements
