Exponential stability of linear periodic difference-delay equations
This paper deals with stability of linear periodic time-varying difference delay systems, i.e. dynamical systems where a finite dimensional signal at a certain time is given as a linear time-varying function of its value at a finite
number of delayed times.
We give a necessary and sufficient condition for exponential stability, that is a generalisation of the one by Henry and Hale in the 1970s.
It has a control theoretic interpretation in terms of the Harmonic Transfer Function of a corresponding linear control system.
